Time Before: 0.00510 seconds
Time After: 0.00740 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00747 seconds
Time After: 0.00784 seconds
Time Before: 0.00805 seconds
Time After: 0.00816 seconds
Time Before: 0.00896 seconds
Time After: 0.01243 seconds
Time Taken: 0.00347 seconds
Time Before: 0.00823 seconds
Time After: 0.01736 seconds
Time Taken: 0.00913 seconds
Time Before: 0.02021 seconds
Time After: 0.02064 seconds
Time Before: 0.02340 seconds
Time After: 0.02540 seconds
Time Taken: 0.00200 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01944 seconds
Time After: 0.02562 seconds
Time Taken: 0.00617 seconds
Memory After: 2,261.820 KB
Time Before: 0.03361 seconds
Time After: 0.03373 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03854 seconds
Time After: 0.03979 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.042207002639771
Time Before: 0.04622 seconds
Time After: 0.04656 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04900 seconds
Time After: 0.05041 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789068091, location = '/forums/private.php?do=newpm&explain=1&u=138267'
Time Before: 0.06637 seconds
Time After: 0.06676 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.065465927124023 seconds with 9 queries, spending 0.0098886489868164 doing MySQL queries and 0.055577278137207 doing PHP things.
