Time Before: 0.01906 seconds
Time After: 0.02499 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02507 seconds
Time After: 0.02547 seconds
Time Before: 0.02574 seconds
Time After: 0.02587 seconds
Time Before: 0.02676 seconds
Time After: 0.02962 seconds
Time Taken: 0.00286 seconds
Time Before: 0.02596 seconds
Time After: 0.03384 seconds
Time Taken: 0.00788 seconds
Time Before: 0.04661 seconds
Time After: 0.04704 seconds
Time Before: 0.04852 seconds
Time After: 0.04971 seconds
Time Before: 0.04586 seconds
Time After: 0.04994 seconds
Time Taken: 0.00408 seconds
Time Before: 0.08232 seconds
Time After: 0.08246 seconds
Time Before: 0.23344 seconds
Time After: 0.23472 seconds
Time Before: 0.24922 seconds
Time After: 0.24970 seconds
Time Before: 0.25249 seconds
Time After: 0.25399 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1780636913, location = '/forums/private.php?do=newpm&explain=1&u=138390', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.27394 seconds
Time After: 0.27422 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
