Time Before: 0.02244 seconds
Time After: 0.03060 seconds
Time Taken: 0.00817 seconds
Time Before: 0.03069 seconds
Time After: 0.03113 seconds
Time Before: 0.03136 seconds
Time After: 0.03154 seconds
Time Before: 0.03232 seconds
Time After: 0.03475 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03160 seconds
Time After: 0.03892 seconds
Time Taken: 0.00732 seconds
Time Before: 0.04821 seconds
Time After: 0.04858 seconds
Time Before: 0.05103 seconds
Time After: 0.05226 seconds
Time Before: 0.04747 seconds
Time After: 0.05253 seconds
Time Taken: 0.00507 seconds
Time Before: 0.08961 seconds
Time After: 0.08977 seconds
Time Before: 0.10298 seconds
Time After: 0.10421 seconds
Time Before: 0.11366 seconds
Time After: 0.11380 seconds
Time Before: 0.11622 seconds
Time After: 0.11772 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1776560362, location = '/forums/private.php?do=newpm&explain=1&u=138410' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.13521 seconds
Time After: 0.13598 seconds
Time Taken: 0.00076 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
