Time Before: 0.01865 seconds
Time After: 0.02651 seconds
Time Taken: 0.00787 seconds
Time Before: 0.02659 seconds
Time After: 0.02707 seconds
Time Before: 0.02735 seconds
Time After: 0.02749 seconds
Time Before: 0.02840 seconds
Time After: 0.03112 seconds
Time Taken: 0.00272 seconds
Time Before: 0.02757 seconds
Time After: 0.03524 seconds
Time Taken: 0.00767 seconds
Time Before: 0.04667 seconds
Time After: 0.04716 seconds
Time Before: 0.05021 seconds
Time After: 0.05145 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04595 seconds
Time After: 0.05170 seconds
Time Taken: 0.00575 seconds
Memory After: 2,261.820 KB
Time Before: 0.08728 seconds
Time After: 0.08741 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.11248 seconds
Time After: 0.11371 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.11561799049377
Time Before: 0.12727 seconds
Time After: 0.12747 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13008 seconds
Time After: 0.13152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788946160, location = '/forums/private.php?do=newpm&explain=1&u=138434', badlocation = 1
Time Before: 0.15123 seconds
Time After: 0.15153 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.15021991729736 seconds with 9 queries, spending 0.0083730220794678 doing MySQL queries and 0.1418468952179 doing PHP things.
