Time Before: 0.00139 seconds
Time After: 0.00195 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00202 seconds
Time After: 0.00250 seconds
Time Before: 0.00280 seconds
Time After: 0.00293 seconds
Time Before: 0.00379 seconds
Time After: 0.00664 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00301 seconds
Time After: 0.01007 seconds
Time Taken: 0.00706 seconds
Time Before: 0.01197 seconds
Time After: 0.01231 seconds
Time Before: 0.01475 seconds
Time After: 0.01600 seconds
Time Before: 0.01134 seconds
Time After: 0.01617 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02118 seconds
Time After: 0.02139 seconds
Time Before: 0.02400 seconds
Time After: 0.02527 seconds
End call of global.php: 0.028062105178833
Time Before: 0.02936 seconds
Time After: 0.02960 seconds
Time Before: 0.03187 seconds
Time After: 0.03334 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=138484', badlocation = 1
Time Before: 0.04553 seconds
Time After: 0.04587 seconds
Page generated in 0.044636964797974 seconds with 9 queries, spending 0.0085928440093994 doing MySQL queries and 0.036044120788574 doing PHP things.
