Time Before: 0.00990 seconds
Time After: 0.01487 seconds
Time Taken: 0.00497 seconds
Time Before: 0.01499 seconds
Time After: 0.01548 seconds
Time Before: 0.01576 seconds
Time After: 0.01592 seconds
Time Before: 0.01682 seconds
Time After: 0.01962 seconds
Time Taken: 0.00279 seconds
Time Before: 0.01600 seconds
Time After: 0.02410 seconds
Time Taken: 0.00811 seconds
Time Before: 0.02939 seconds
Time After: 0.02960 seconds
Time Before: 0.03112 seconds
Time After: 0.03233 seconds
Time Before: 0.02876 seconds
Time After: 0.03256 seconds
Time Taken: 0.00380 seconds
Time Before: 0.05560 seconds
Time After: 0.05575 seconds
Time Before: 0.06634 seconds
Time After: 0.06769 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.069746017456055
Time Before: 0.07428 seconds
Time After: 0.07445 seconds
Time Before: 0.07682 seconds
Time After: 0.07837 seconds
Time Taken: 0.00154 seconds
SET lastactivity = 1784738204, location = '/forums/private.php?do=newpm&explain=1&u=138492', badlocation = 1
Time Before: 0.09299 seconds
Time After: 0.09330 seconds
Page generated in 0.0920250415802 seconds with 9 queries, spending 0.0083987712860107 doing MySQL queries and 0.083626270294189 doing PHP things.
