Time Before: 0.01782 seconds
Time After: 0.02445 seconds
Time Taken: 0.00663 seconds
Time Before: 0.02453 seconds
Time After: 0.02497 seconds
Time Before: 0.02519 seconds
Time After: 0.02533 seconds
Time Before: 0.02610 seconds
Time After: 0.02867 seconds
Time Taken: 0.00257 seconds
Time Before: 0.02540 seconds
Time After: 0.03252 seconds
Time Taken: 0.00711 seconds
Time Before: 0.04219 seconds
Time After: 0.04259 seconds
Time Before: 0.04573 seconds
Time After: 0.04700 seconds
Time Before: 0.04137 seconds
Time After: 0.04725 seconds
Time Taken: 0.00588 seconds
Time Before: 0.07243 seconds
Time After: 0.07258 seconds
Time Before: 0.08543 seconds
Time After: 0.08670 seconds
Time Before: 0.09541 seconds
Time After: 0.09561 seconds
Time Before: 0.09850 seconds
Time After: 0.09994 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138507' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.11871 seconds
Time After: 0.11898 seconds
