Time Before: 0.00204 seconds
Time After: 0.00261 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00271 seconds
Time After: 0.00326 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00354 seconds
Time After: 0.00364 seconds
Time Before: 0.00432 seconds
Time After: 0.00694 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00369 seconds
Time After: 0.01035 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01211 seconds
Time After: 0.01246 seconds
Time Before: 0.01480 seconds
Time After: 0.01607 seconds
Time Before: 0.01157 seconds
Time After: 0.01624 seconds
Time Taken: 0.00467 seconds
Time Before: 0.02096 seconds
Time After: 0.02108 seconds
Time Before: 0.02326 seconds
Time After: 0.02449 seconds
End call of global.php: 0.026108026504517
Time Before: 0.02738 seconds
Time After: 0.02754 seconds
Time Before: 0.02958 seconds
Time After: 0.03108 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1776583574, location = '/forums/private.php?do=newpm&explain=1&u=138521', badlocation = 1
Time Before: 0.04353 seconds
Time After: 0.04381 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.04261302947998 seconds with 9 queries, spending 0.0082011222839355 doing MySQL queries and 0.034411907196045 doing PHP things.
