Time Before: 0.00146 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00241 seconds
Time Before: 0.00270 seconds
Time After: 0.00286 seconds
Time Before: 0.00376 seconds
Time After: 0.00661 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00294 seconds
Time After: 0.01211 seconds
Time Taken: 0.00916 seconds
Time Before: 0.01457 seconds
Time After: 0.01495 seconds
Time Before: 0.01757 seconds
Time After: 0.01880 seconds
Time Before: 0.01379 seconds
Time After: 0.01907 seconds
Time Taken: 0.00528 seconds
Time Before: 0.02725 seconds
Time After: 0.02741 seconds
Time Before: 0.02948 seconds
Time After: 0.03076 seconds
End call of global.php: 0.033411026000977
Time Before: 0.03528 seconds
Time After: 0.03549 seconds
Time Before: 0.03862 seconds
Time After: 0.04012 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1783162081, location = '/forums/private.php?do=newpm&explain=1&u=138531', badlocation = 1
Time Before: 0.05850 seconds
Time After: 0.05886 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.057554960250854 seconds with 9 queries, spending 0.0085568428039551 doing MySQL queries and 0.048998117446899 doing PHP things.
