Time Before: 0.00137 seconds
Time After: 0.00191 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00198 seconds
Time After: 0.00232 seconds
Time Before: 0.00257 seconds
Time After: 0.00274 seconds
Time Before: 0.00346 seconds
Time After: 0.00581 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00279 seconds
Time After: 0.01080 seconds
Time Taken: 0.00801 seconds
Time Before: 0.01300 seconds
Time After: 0.01339 seconds
Time Before: 0.01618 seconds
Time After: 0.01740 seconds
Time Before: 0.01229 seconds
Time After: 0.01774 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02703 seconds
Time After: 0.02716 seconds
Time Before: 0.03051 seconds
Time After: 0.03174 seconds
End call of global.php: 0.033666849136353
Time Before: 0.03505 seconds
Time After: 0.03522 seconds
Time Before: 0.03796 seconds
Time After: 0.03940 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=138611', badlocation = 1
Time Before: 0.05380 seconds
Time After: 0.05406 seconds
Page generated in 0.052876949310303 seconds with 9 queries, spending 0.0077099800109863 doing MySQL queries and 0.045166969299316 doing PHP things.
