Time Before: 0.01617 seconds
Time After: 0.01957 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01968 seconds
Time After: 0.02000 seconds
Time Before: 0.02021 seconds
Time After: 0.02031 seconds
Time Taken: 0.00010 seconds
Time Before: 0.02095 seconds
Time After: 0.02342 seconds
Time Taken: 0.00248 seconds
Time Before: 0.02039 seconds
Time After: 0.02753 seconds
Time Taken: 0.00714 seconds
Time Before: 0.03563 seconds
Time After: 0.03584 seconds
Time Before: 0.03830 seconds
Time After: 0.03948 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03488 seconds
Time After: 0.03968 seconds
Time Taken: 0.00480 seconds
Time Before: 0.07231 seconds
Time After: 0.07247 seconds
Time Before: 1.13872 seconds
Time After: 1.14055 seconds
Time Taken: 0.00183 seconds
Time Before: 1.15022 seconds
Time After: 1.15039 seconds
Time Before: 1.15272 seconds
Time After: 1.15421 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138620' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 1.17278 seconds
Time After: 1.17299 seconds
