Time Before: 0.01916 seconds
Time After: 0.02816 seconds
Time Taken: 0.00901 seconds
Time Before: 0.02829 seconds
Time After: 0.02879 seconds
Time Before: 0.02924 seconds
Time After: 0.02942 seconds
Time Before: 0.03040 seconds
Time After: 0.03323 seconds
Time Taken: 0.00284 seconds
Time Before: 0.02953 seconds
Time After: 0.03798 seconds
Time Taken: 0.00845 seconds
Time Before: 0.04991 seconds
Time After: 0.05009 seconds
Time Before: 0.05299 seconds
Time After: 0.05422 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04913 seconds
Time After: 0.05447 seconds
Time Taken: 0.00534 seconds
Memory After: 2,261.820 KB
Time Before: 0.10679 seconds
Time After: 0.10697 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.13052 seconds
Time After: 0.13181 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.14005 seconds
Time After: 0.14020 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.14302 seconds
Time After: 0.14446 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789115607, location = '/forums/private.php?do=newpm&explain=1&u=138639' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.16363 seconds
Time After: 0.16389 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
