Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00247 seconds
Time Before: 0.00267 seconds
Time After: 0.00282 seconds
Time Before: 0.00346 seconds
Time After: 0.00588 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00287 seconds
Time After: 0.00948 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01189 seconds
Time After: 0.01235 seconds
Time Before: 0.01506 seconds
Time After: 0.01631 seconds
Time Before: 0.01111 seconds
Time After: 0.01655 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02206 seconds
Time After: 0.02221 seconds
Time Before: 0.02412 seconds
Time After: 0.02536 seconds
End call of global.php: 0.027025938034058
Time Before: 0.02828 seconds
Time After: 0.02845 seconds
Time Before: 0.03128 seconds
Time After: 0.03298 seconds
Time Taken: 0.00170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=13864'
Time Before: 0.04800 seconds
Time After: 0.04830 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047080993652344 seconds with 9 queries, spending 0.0083372592926025 doing MySQL queries and 0.038743734359741 doing PHP things.
