Time Before: 0.00498 seconds
Time After: 0.00803 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00810 seconds
Time After: 0.00849 seconds
Time Before: 0.00901 seconds
Time After: 0.00913 seconds
Time Before: 0.00991 seconds
Time After: 0.01430 seconds
Time Taken: 0.00439 seconds
Time Before: 0.00919 seconds
Time After: 0.01925 seconds
Time Taken: 0.01006 seconds
Time Before: 0.02451 seconds
Time After: 0.02497 seconds
Time Before: 0.02804 seconds
Time After: 0.02924 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02379 seconds
Time After: 0.02943 seconds
Time Taken: 0.00564 seconds
Memory After: 2,261.719 KB
Memory Used: 132.781 KB
Time Before: 0.04036 seconds
Time After: 0.04050 seconds
Memory Before: 2,815.305 KB
Memory After: 2,815.820 KB
Time Before: 0.04857 seconds
Time After: 0.05005 seconds
Memory Before: 2,903.508 KB
Memory After: 2,904.102 KB
Time Before: 0.05523 seconds
Time After: 0.05537 seconds
Memory Before: 3,540.266 KB
Memory After: 3,540.695 KB
Time Before: 0.05748 seconds
Time After: 0.05895 seconds
Memory Before: 3,821.797 KB
Memory After: 3,823.484 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138674' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07539 seconds
Time After: 0.07577 seconds
Memory Before: 4,287.211 KB
Memory After: 4,287.453 KB
