Time Before: 0.00144 seconds
Time After: 0.00194 seconds
Time Before: 0.00205 seconds
Time After: 0.00253 seconds
Time Before: 0.00277 seconds
Time After: 0.00293 seconds
Time Before: 0.00375 seconds
Time After: 0.00648 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00301 seconds
Time After: 0.00991 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01161 seconds
Time After: 0.01198 seconds
Time Before: 0.01449 seconds
Time After: 0.01584 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01104 seconds
Time After: 0.01608 seconds
Time Taken: 0.00505 seconds
Time Before: 0.02140 seconds
Time After: 0.02160 seconds
Time Before: 0.02354 seconds
Time After: 0.02489 seconds
Time Before: 0.02821 seconds
Time After: 0.02847 seconds
Time Before: 0.03148 seconds
Time After: 0.03293 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138709' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04548 seconds
Time After: 0.05082 seconds
Time Taken: 0.00534 seconds
