Time Before: 0.03111 seconds
Time After: 0.03701 seconds
Time Taken: 0.00590 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03711 seconds
Time After: 0.03764 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03787 seconds
Time After: 0.03800 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03892 seconds
Time After: 0.04179 seconds
Time Taken: 0.00286 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03808 seconds
Time After: 0.04587 seconds
Time Taken: 0.00779 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.05708 seconds
Time After: 0.05746 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.06006 seconds
Time After: 0.06126 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.05638 seconds
Time After: 0.06150 seconds
Time Taken: 0.00512 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.672 KB
Time Before: 0.10655 seconds
Time After: 0.10669 seconds
Memory Before: 2,815.242 KB
Memory After: 2,815.758 KB
Time Before: 0.12818 seconds
Time After: 0.12956 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
End call of global.php: 0.13192892074585
Time Before: 0.13906 seconds
Time After: 0.13921 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14166 seconds
Time After: 0.14309 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=138781'
Time Before: 0.16551 seconds
Time After: 0.16581 seconds
Memory Before: 4,295.492 KB
Memory After: 4,295.734 KB
Page generated in 0.16403889656067 seconds with 9 queries, spending 0.0085089206695557 doing MySQL queries and 0.15552997589111 doing PHP things.
