Time Before: 0.00705 seconds
Time After: 0.00916 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00925 seconds
Time After: 0.00979 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01002 seconds
Time After: 0.01016 seconds
Time Before: 0.01096 seconds
Time After: 0.01301 seconds
Time Taken: 0.00205 seconds
Time Before: 0.01021 seconds
Time After: 0.01745 seconds
Time Taken: 0.00723 seconds
Time Before: 0.02297 seconds
Time After: 0.02336 seconds
Time Before: 0.02655 seconds
Time After: 0.02778 seconds
Time Before: 0.02231 seconds
Time After: 0.02805 seconds
Time Taken: 0.00574 seconds
Time Before: 0.04530 seconds
Time After: 0.04544 seconds
Time Before: 0.05111 seconds
Time After: 0.05235 seconds
Time Before: 0.05961 seconds
Time After: 0.05977 seconds
Time Before: 0.06249 seconds
Time After: 0.06391 seconds
UPDATE session SET lastactivity = 1785289485, location = '/forums/private.php?do=newpm&explain=1&u=138803' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.08051 seconds
Time After: 0.08083 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
