Time Before: 0.00139 seconds
Time After: 0.00194 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00200 seconds
Time After: 0.00270 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00295 seconds
Time After: 0.00315 seconds
Time Before: 0.00384 seconds
Time After: 0.00709 seconds
Time Taken: 0.00325 seconds
Time Before: 0.00321 seconds
Time After: 0.01050 seconds
Time Taken: 0.00729 seconds
Time Before: 0.01239 seconds
Time After: 0.01285 seconds
Time Before: 0.01524 seconds
Time After: 0.01863 seconds
Time Taken: 0.00338 seconds
Time Before: 0.01177 seconds
Time After: 0.01881 seconds
Time Taken: 0.00704 seconds
Time Before: 0.02410 seconds
Time After: 0.02425 seconds
Time Before: 0.02647 seconds
Time After: 0.02774 seconds
Time Before: 0.03065 seconds
Time After: 0.03128 seconds
Time Taken: 0.00063 seconds
Time Before: 0.03329 seconds
Time After: 0.03525 seconds
Time Taken: 0.00196 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138851', badlocation = 1 WHERE sessionhash = '498d073752497ccaba409783e9267bef'
Time Before: 0.04767 seconds
Time After: 0.04802 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
