Time Before: 0.02252 seconds
Time After: 0.02833 seconds
Time Taken: 0.00581 seconds
Time Before: 0.02845 seconds
Time After: 0.02886 seconds
Time Before: 0.02921 seconds
Time After: 0.02932 seconds
Time Before: 0.03013 seconds
Time After: 0.03212 seconds
Time Taken: 0.00199 seconds
Time Before: 0.02940 seconds
Time After: 0.03574 seconds
Time Taken: 0.00634 seconds
Time Before: 0.04289 seconds
Time After: 0.04325 seconds
Time Before: 0.04542 seconds
Time After: 0.04666 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04211 seconds
Time After: 0.04694 seconds
Time Taken: 0.00483 seconds
Memory After: 2,261.820 KB
Time Before: 0.07557 seconds
Time After: 0.07573 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09666 seconds
Time After: 0.09791 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10755 seconds
Time After: 0.10776 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11042 seconds
Time After: 0.11190 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788949484, location = '/forums/private.php?do=newpm&explain=1&u=138857', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13189 seconds
Time After: 0.13216 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
