Time Before: 0.01330 seconds
Time After: 0.01789 seconds
Time Taken: 0.00459 seconds
Time Before: 0.01800 seconds
Time After: 0.01847 seconds
Time Before: 0.01873 seconds
Time After: 0.01886 seconds
Time Before: 0.01978 seconds
Time After: 0.02211 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01896 seconds
Time After: 0.02626 seconds
Time Taken: 0.00731 seconds
Time Before: 0.03099 seconds
Time After: 0.03146 seconds
Time Before: 0.03465 seconds
Time After: 0.03592 seconds
Time Before: 0.03018 seconds
Time After: 0.03610 seconds
Time Taken: 0.00592 seconds
Time Before: 0.06399 seconds
Time After: 0.06426 seconds
Time Before: 0.07747 seconds
Time After: 0.07874 seconds
End call of global.php: 0.081755876541138
Time Before: 0.08580 seconds
Time After: 0.08597 seconds
Time Before: 0.08907 seconds
Time After: 0.09053 seconds
SET lastactivity = 1785321285, location = '/forums/private.php?do=newpm&explain=1&u=138863'
Time Before: 0.10967 seconds
Time After: 0.10998 seconds
Page generated in 0.10853600502014 seconds with 9 queries, spending 0.0081391334533691 doing MySQL queries and 0.10039687156677 doing PHP things.
