Time Before: 0.00143 seconds
Time After: 0.00216 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00230 seconds
Time After: 0.00272 seconds
Time Before: 0.00322 seconds
Time After: 0.00337 seconds
Time Before: 0.00412 seconds
Time After: 0.00680 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00342 seconds
Time After: 0.01170 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01348 seconds
Time After: 0.01392 seconds
Time Before: 0.01685 seconds
Time After: 0.01804 seconds
Time Before: 0.01285 seconds
Time After: 0.01821 seconds
Time Taken: 0.00536 seconds
Time Before: 0.02438 seconds
Time After: 0.02451 seconds
Time Before: 0.02645 seconds
Time After: 0.02766 seconds
End call of global.php: 0.030375957489014
Time Before: 0.03172 seconds
Time After: 0.03188 seconds
Time Before: 0.03506 seconds
Time After: 0.03652 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=138868', badlocation = 1
Time Before: 0.05227 seconds
Time After: 0.05250 seconds
Page generated in 0.051332950592041 seconds with 9 queries, spending 0.008073091506958 doing MySQL queries and 0.043259859085083 doing PHP things.
