Time Before: 0.00144 seconds
Time After: 0.00196 seconds
Time Before: 0.00203 seconds
Time After: 0.00242 seconds
Time Before: 0.00263 seconds
Time After: 0.00273 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00337 seconds
Time After: 0.00600 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00278 seconds
Time After: 0.00941 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01122 seconds
Time After: 0.01158 seconds
Time Before: 0.01416 seconds
Time After: 0.01535 seconds
Time Before: 0.01066 seconds
Time After: 0.01552 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02039 seconds
Time After: 0.02057 seconds
Time Before: 0.02259 seconds
Time After: 0.02387 seconds
End call of global.php: 0.025471925735474
Time Before: 0.02678 seconds
Time After: 0.02693 seconds
Time Before: 0.02885 seconds
Time After: 0.03024 seconds
Time Taken: 0.00139 seconds
SET lastactivity = 1783017849, location = '/forums/private.php?do=newpm&explain=1&u=138904'
Time Before: 0.04360 seconds
Time After: 0.04394 seconds
Page generated in 0.042702913284302 seconds with 9 queries, spending 0.0080206394195557 doing MySQL queries and 0.034682273864746 doing PHP things.
