Time Before: 0.01387 seconds
Time After: 0.01744 seconds
Time Taken: 0.00356 seconds
Time Before: 0.01754 seconds
Time After: 0.01793 seconds
Time Before: 0.01855 seconds
Time After: 0.01895 seconds
Time Before: 0.02017 seconds
Time After: 0.02264 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01904 seconds
Time After: 0.02632 seconds
Time Taken: 0.00729 seconds
Time Before: 0.03184 seconds
Time After: 0.03223 seconds
Time Before: 0.03499 seconds
Time After: 0.03622 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03096 seconds
Time After: 0.03643 seconds
Time Taken: 0.00547 seconds
Memory After: 2,261.703 KB
Time Before: 0.06596 seconds
Time After: 0.06610 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.20300 seconds
Time After: 0.20425 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.21158 seconds
Time After: 0.21173 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.21395 seconds
Time After: 0.21618 seconds
Time Taken: 0.00222 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138927', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.23346 seconds
Time After: 0.23378 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
