Time Before: 0.00196 seconds
Time After: 0.00296 seconds
Time Taken: 0.00100 seconds
Time Before: 0.00311 seconds
Time After: 0.00412 seconds
Time Before: 0.00452 seconds
Time After: 0.00502 seconds
Time Before: 0.00564 seconds
Time After: 0.00908 seconds
Time Taken: 0.00344 seconds
Time Before: 0.00508 seconds
Time After: 0.01394 seconds
Time Taken: 0.00886 seconds
Time Before: 0.01685 seconds
Time After: 0.01805 seconds
Time Before: 0.02065 seconds
Time After: 0.02186 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01597 seconds
Time After: 0.02211 seconds
Time Taken: 0.00614 seconds
Memory After: 2,261.703 KB
Time Before: 0.03074 seconds
Time After: 0.03183 seconds
Time Taken: 0.00109 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03675 seconds
Time After: 0.03853 seconds
Time Taken: 0.00178 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.04256 seconds
Time After: 0.04271 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04575 seconds
Time After: 0.04772 seconds
Time Taken: 0.00197 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138941' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.06471 seconds
Time After: 0.06501 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
