Time Before: 0.02352 seconds
Time After: 0.03289 seconds
Time Taken: 0.00936 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03300 seconds
Time After: 0.03364 seconds
Time Taken: 0.00063 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03402 seconds
Time After: 0.03418 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03510 seconds
Time After: 0.03820 seconds
Time Taken: 0.00310 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03429 seconds
Time After: 0.04264 seconds
Time Taken: 0.00836 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04907 seconds
Time After: 0.04949 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05259 seconds
Time After: 0.05382 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04822 seconds
Time After: 0.05405 seconds
Time Taken: 0.00583 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.10812 seconds
Time After: 0.10832 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.39346 seconds
Time After: 0.39489 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.39698815345764
Time Before: 0.42347 seconds
Time After: 0.42366 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.43083 seconds
Time After: 0.43232 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773081341, location = '/forums/private.php?do=newpm&explain=1&u=138950', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.46146 seconds
Time After: 0.46171 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.46043109893799 seconds with 9 queries, spending 0.0091257095336914 doing MySQL queries and 0.4513053894043 doing PHP things.
