Time Before: 0.01515 seconds
Time After: 0.02281 seconds
Time Taken: 0.00765 seconds
Time Before: 0.02289 seconds
Time After: 0.02347 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02379 seconds
Time After: 0.02402 seconds
Time Before: 0.02494 seconds
Time After: 0.02783 seconds
Time Taken: 0.00289 seconds
Time Before: 0.02411 seconds
Time After: 0.03221 seconds
Time Taken: 0.00810 seconds
Time Before: 0.03778 seconds
Time After: 0.03820 seconds
Time Before: 0.04085 seconds
Time After: 0.04215 seconds
Time Before: 0.03694 seconds
Time After: 0.04242 seconds
Time Taken: 0.00548 seconds
Time Before: 0.06512 seconds
Time After: 0.06532 seconds
Time Before: 0.08589 seconds
Time After: 0.08722 seconds
Time Taken: 0.00132 seconds
Time Before: 0.09842 seconds
Time After: 0.09865 seconds
Time Before: 0.10150 seconds
Time After: 0.10301 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1784802861, location = '/forums/private.php?do=newpm&explain=1&u=138970', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.12278 seconds
Time After: 0.12311 seconds
