Time Before: 0.00726 seconds
Time After: 0.00950 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00959 seconds
Time After: 0.01000 seconds
Time Before: 0.01021 seconds
Time After: 0.01037 seconds
Time Before: 0.01105 seconds
Time After: 0.01341 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01042 seconds
Time After: 0.01847 seconds
Time Taken: 0.00805 seconds
Time Before: 0.02270 seconds
Time After: 0.02314 seconds
Time Before: 0.02470 seconds
Time After: 0.02591 seconds
Time Before: 0.02196 seconds
Time After: 0.02616 seconds
Time Taken: 0.00420 seconds
Time Before: 0.04160 seconds
Time After: 0.04172 seconds
Time Before: 0.04717 seconds
Time After: 0.04842 seconds
End call of global.php: 0.051007986068726
Time Before: 0.05379 seconds
Time After: 0.05394 seconds
Time Before: 0.05641 seconds
Time After: 0.05783 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139024', badlocation = 1
Time Before: 0.07429 seconds
Time After: 0.07457 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.073161125183105 seconds with 9 queries, spending 0.0077929496765137 doing MySQL queries and 0.065368175506592 doing PHP things.
