Time Before: 0.02012 seconds
Time After: 0.02756 seconds
Time Taken: 0.00744 seconds
Time Before: 0.02763 seconds
Time After: 0.02804 seconds
Time Before: 0.02824 seconds
Time After: 0.02837 seconds
Time Before: 0.02906 seconds
Time After: 0.03164 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02842 seconds
Time After: 0.03577 seconds
Time Taken: 0.00735 seconds
Time Before: 0.04654 seconds
Time After: 0.04698 seconds
Time Before: 0.04948 seconds
Time After: 0.05081 seconds
Time Taken: 0.00133 seconds
Time Before: 0.04582 seconds
Time After: 0.05103 seconds
Time Taken: 0.00521 seconds
Time Before: 0.10072 seconds
Time After: 0.10084 seconds
Time Before: 0.12253 seconds
Time After: 0.12379 seconds
Time Before: 0.13091 seconds
Time After: 0.13105 seconds
Time Before: 0.13370 seconds
Time After: 0.13582 seconds
Time Taken: 0.00212 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139042' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.15162 seconds
Time After: 0.15197 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
