Time Before: 0.00198 seconds
Time After: 0.00270 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00283 seconds
Time After: 0.00332 seconds
Time Before: 0.00355 seconds
Time After: 0.00368 seconds
Time Before: 0.00436 seconds
Time After: 0.00778 seconds
Time Taken: 0.00342 seconds
Time Before: 0.00373 seconds
Time After: 0.01117 seconds
Time Taken: 0.00743 seconds
Time Before: 0.01301 seconds
Time After: 0.01327 seconds
Time Before: 0.01552 seconds
Time After: 0.01671 seconds
Time Before: 0.01239 seconds
Time After: 0.01689 seconds
Time Taken: 0.00450 seconds
Time Before: 0.02211 seconds
Time After: 0.02224 seconds
Time Before: 0.02425 seconds
Time After: 0.02552 seconds
End call of global.php: 0.027147054672241
Time Before: 0.02824 seconds
Time After: 0.02836 seconds
Time Before: 0.03033 seconds
Time After: 0.03190 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1783076044, location = '/forums/private.php?do=newpm&explain=1&u=13905'
Time Before: 0.04620 seconds
Time After: 0.04645 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.045186042785645 seconds with 9 queries, spending 0.0088589191436768 doing MySQL queries and 0.036327123641968 doing PHP things.
