Time Before: 0.02267 seconds
Time After: 0.02910 seconds
Time Taken: 0.00643 seconds
Time Before: 0.02917 seconds
Time After: 0.03033 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03074 seconds
Time After: 0.03097 seconds
Time Before: 0.03180 seconds
Time After: 0.03409 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03105 seconds
Time After: 0.03834 seconds
Time Taken: 0.00730 seconds
Time Before: 0.04683 seconds
Time After: 0.04751 seconds
Time Taken: 0.00068 seconds
Time Before: 0.05014 seconds
Time After: 0.05130 seconds
Time Before: 0.04596 seconds
Time After: 0.05150 seconds
Time Taken: 0.00554 seconds
Time Before: 0.09145 seconds
Time After: 0.09165 seconds
Time Before: 0.11004 seconds
Time After: 0.11129 seconds
End call of global.php: 0.11343812942505
Time Before: 0.12358 seconds
Time After: 0.12377 seconds
Time Before: 0.12628 seconds
Time After: 0.12776 seconds
SET lastactivity = 1783094702, location = '/forums/private.php?do=newpm&explain=1&u=139070', badlocation = 1
Time Before: 0.14634 seconds
Time After: 0.14665 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.14519214630127 seconds with 9 queries, spending 0.0089492797851562 doing MySQL queries and 0.13624286651611 doing PHP things.
