Time Before: 0.00805 seconds
Time After: 0.00997 seconds
Time Taken: 0.00192 seconds
Time Before: 0.01007 seconds
Time After: 0.01052 seconds
Time Before: 0.01077 seconds
Time After: 0.01096 seconds
Time Before: 0.01169 seconds
Time After: 0.01416 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01102 seconds
Time After: 0.01841 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02197 seconds
Time After: 0.02247 seconds
Time Before: 0.02483 seconds
Time After: 0.02600 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02139 seconds
Time After: 0.02620 seconds
Time Taken: 0.00481 seconds
Time Before: 0.04247 seconds
Time After: 0.04262 seconds
Time Before: 0.04864 seconds
Time After: 0.04996 seconds
Time Taken: 0.00132 seconds
Time Before: 0.05574 seconds
Time After: 0.05589 seconds
Time Before: 0.05803 seconds
Time After: 0.05943 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139114', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07539 seconds
Time After: 0.07566 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
