Time Before: 0.02310 seconds
Time After: 0.02959 seconds
Time Taken: 0.00649 seconds
Time Before: 0.02968 seconds
Time After: 0.03010 seconds
Time Before: 0.03043 seconds
Time After: 0.03058 seconds
Time Before: 0.03139 seconds
Time After: 0.03371 seconds
Time Taken: 0.00231 seconds
Time Before: 0.03065 seconds
Time After: 0.03766 seconds
Time Taken: 0.00700 seconds
Time Before: 0.04703 seconds
Time After: 0.04745 seconds
Time Before: 0.05107 seconds
Time After: 0.05234 seconds
Time Before: 0.04550 seconds
Time After: 0.05257 seconds
Time Taken: 0.00707 seconds
Time Before: 0.08747 seconds
Time After: 0.08774 seconds
Time Before: 0.12777 seconds
Time After: 0.12903 seconds
Time Before: 0.14116 seconds
Time After: 0.14134 seconds
Time Before: 0.14435 seconds
Time After: 0.14581 seconds
UPDATE session SET lastactivity = 1783060017, location = '/forums/private.php?do=newpm&explain=1&u=139187', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.16352 seconds
Time After: 0.16389 seconds
