Time Before: 0.01324 seconds
Time After: 0.01764 seconds
Time Taken: 0.00440 seconds
Time Before: 0.01774 seconds
Time After: 0.01826 seconds
Time Before: 0.01852 seconds
Time After: 0.01864 seconds
Time Before: 0.01942 seconds
Time After: 0.02200 seconds
Time Taken: 0.00258 seconds
Time Before: 0.01871 seconds
Time After: 0.02606 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03057 seconds
Time After: 0.03101 seconds
Time Before: 0.03380 seconds
Time After: 0.03505 seconds
Time Before: 0.02990 seconds
Time After: 0.03529 seconds
Time Taken: 0.00539 seconds
Time Before: 0.06233 seconds
Time After: 0.06257 seconds
Time Before: 0.07908 seconds
Time After: 0.08042 seconds
Time Taken: 0.00133 seconds
Time Before: 0.08927 seconds
Time After: 0.08944 seconds
Time Before: 0.09202 seconds
Time After: 0.09362 seconds
Time Taken: 0.00160 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139191', badlocation = 1 WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.11013 seconds
Time After: 0.11038 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
