Time Before: 0.02963 seconds
Time After: 0.03866 seconds
Time Taken: 0.00903 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03874 seconds
Time After: 0.03935 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03965 seconds
Time After: 0.03982 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.04058 seconds
Time After: 0.04323 seconds
Time Taken: 0.00265 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03989 seconds
Time After: 0.04763 seconds
Time Taken: 0.00774 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05616 seconds
Time After: 0.05640 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05794 seconds
Time After: 0.05919 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.05531 seconds
Time After: 0.05942 seconds
Time Taken: 0.00411 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.10815 seconds
Time After: 0.10834 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.17586 seconds
Time After: 0.17713 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.20525 seconds
Time After: 0.20541 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.21209 seconds
Time After: 0.21365 seconds
Time Taken: 0.00156 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772862854, location = '/forums/private.php?do=newpm&explain=1&u=139233', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.24197 seconds
Time After: 0.24229 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
