Time Before: 0.00192 seconds
Time After: 0.00258 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00268 seconds
Time After: 0.00333 seconds
Time Before: 0.00357 seconds
Time After: 0.00369 seconds
Time Before: 0.00443 seconds
Time After: 0.00745 seconds
Time Taken: 0.00302 seconds
Time Before: 0.00374 seconds
Time After: 0.01129 seconds
Time Taken: 0.00756 seconds
Time Before: 0.01313 seconds
Time After: 0.01353 seconds
Time Before: 0.01498 seconds
Time After: 0.01623 seconds
Time Before: 0.01250 seconds
Time After: 0.01640 seconds
Time Taken: 0.00390 seconds
Time Before: 0.02169 seconds
Time After: 0.02184 seconds
Time Before: 0.02416 seconds
Time After: 0.02540 seconds
End call of global.php: 0.027115106582642
Time Before: 0.02858 seconds
Time After: 0.02872 seconds
Time Before: 0.03074 seconds
Time After: 0.03215 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139238', badlocation = 1
Time Before: 0.04464 seconds
Time After: 0.04500 seconds
Page generated in 0.043726921081543 seconds with 9 queries, spending 0.0087449550628662 doing MySQL queries and 0.034981966018677 doing PHP things.
