Time Before: 0.00616 seconds
Time After: 0.00869 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00880 seconds
Time After: 0.00927 seconds
Time Before: 0.00950 seconds
Time After: 0.00963 seconds
Time Before: 0.01048 seconds
Time After: 0.01268 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00970 seconds
Time After: 0.01732 seconds
Time Taken: 0.00762 seconds
Time Before: 0.02170 seconds
Time After: 0.02209 seconds
Time Before: 0.02452 seconds
Time After: 0.02574 seconds
Time Before: 0.02094 seconds
Time After: 0.02596 seconds
Time Taken: 0.00503 seconds
Time Before: 0.03933 seconds
Time After: 0.03954 seconds
Time Before: 0.04558 seconds
Time After: 0.04703 seconds
Time Before: 0.05313 seconds
Time After: 0.05332 seconds
Time Before: 0.05610 seconds
Time After: 0.05756 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139249', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07530 seconds
Time After: 0.07561 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
