Time Before: 0.01389 seconds
Time After: 0.01783 seconds
Time Taken: 0.00394 seconds
Time Before: 0.01793 seconds
Time After: 0.01833 seconds
Time Before: 0.01855 seconds
Time After: 0.01867 seconds
Time Before: 0.01945 seconds
Time After: 0.02171 seconds
Time Taken: 0.00226 seconds
Time Before: 0.01873 seconds
Time After: 0.02757 seconds
Time Taken: 0.00884 seconds
Time Before: 0.03417 seconds
Time After: 0.03457 seconds
Time Before: 0.03758 seconds
Time After: 0.03880 seconds
Time Before: 0.03338 seconds
Time After: 0.03904 seconds
Time Taken: 0.00566 seconds
Time Before: 0.06818 seconds
Time After: 0.06832 seconds
Time Before: 0.08213 seconds
Time After: 0.08338 seconds
Time Before: 0.09246 seconds
Time After: 0.09262 seconds
Time Before: 0.09575 seconds
Time After: 0.09722 seconds
UPDATE session SET lastactivity = 1776706512, location = '/forums/private.php?do=newpm&explain=1&u=13926', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.11765 seconds
Time After: 0.11795 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
