Time Before: 0.02313 seconds
Time After: 0.02933 seconds
Time Taken: 0.00620 seconds
Time Before: 0.02943 seconds
Time After: 0.02983 seconds
Time Before: 0.03005 seconds
Time After: 0.03017 seconds
Time Before: 0.03095 seconds
Time After: 0.03320 seconds
Time Taken: 0.00225 seconds
Time Before: 0.03023 seconds
Time After: 0.03753 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04630 seconds
Time After: 0.04681 seconds
Time Before: 0.04841 seconds
Time After: 0.04964 seconds
Time Before: 0.04562 seconds
Time After: 0.04989 seconds
Time Taken: 0.00426 seconds
Time Before: 0.08849 seconds
Time After: 0.08864 seconds
Time Before: 0.10346 seconds
Time After: 0.10470 seconds
Time Before: 0.12068 seconds
Time After: 0.12083 seconds
Time Before: 0.12324 seconds
Time After: 0.12471 seconds
UPDATE session SET lastactivity = 1785301769, location = '/forums/private.php?do=newpm&explain=1&u=139266', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.13952 seconds
Time After: 0.13984 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
