Time Before: 0.00196 seconds
Time After: 0.00276 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00283 seconds
Time After: 0.00328 seconds
Time Before: 0.00351 seconds
Time After: 0.00365 seconds
Time Before: 0.00433 seconds
Time After: 0.00693 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00370 seconds
Time After: 0.01129 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01348 seconds
Time After: 0.01386 seconds
Time Before: 0.01623 seconds
Time After: 0.01747 seconds
Time Before: 0.01288 seconds
Time After: 0.01765 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02269 seconds
Time After: 0.02288 seconds
Time Before: 0.02534 seconds
Time After: 0.02659 seconds
Time Before: 0.02961 seconds
Time After: 0.02980 seconds
Time Before: 0.03188 seconds
Time After: 0.03332 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139267' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04569 seconds
Time After: 0.04601 seconds
