Time Before: 0.01751 seconds
Time After: 0.02211 seconds
Time Taken: 0.00460 seconds
Time Before: 0.02224 seconds
Time After: 0.02315 seconds
Time Taken: 0.00091 seconds
Time Before: 0.02340 seconds
Time After: 0.02351 seconds
Time Before: 0.02435 seconds
Time After: 0.02679 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02358 seconds
Time After: 0.03129 seconds
Time Taken: 0.00770 seconds
Time Before: 0.03583 seconds
Time After: 0.03682 seconds
Time Taken: 0.00099 seconds
Time Before: 0.03819 seconds
Time After: 0.03945 seconds
Time Before: 0.03505 seconds
Time After: 0.03964 seconds
Time Taken: 0.00459 seconds
Time Before: 0.07252 seconds
Time After: 0.07266 seconds
Time Before: 0.08631 seconds
Time After: 0.08756 seconds
End call of global.php: 0.089565992355347
Time Before: 0.09446 seconds
Time After: 0.09459 seconds
Time Before: 0.09717 seconds
Time After: 0.09867 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139275', badlocation = 1
Time Before: 0.11530 seconds
Time After: 0.11554 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.11428308486938 seconds with 9 queries, spending 0.0089740753173828 doing MySQL queries and 0.105309009552 doing PHP things.
