Time Before: 0.00194 seconds
Time After: 0.00245 seconds
Time Before: 0.00253 seconds
Time After: 0.00295 seconds
Time Before: 0.00315 seconds
Time After: 0.00327 seconds
Time Before: 0.00407 seconds
Time After: 0.00623 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00332 seconds
Time After: 0.00984 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01166 seconds
Time After: 0.01209 seconds
Time Before: 0.01544 seconds
Time After: 0.01677 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01101 seconds
Time After: 0.01704 seconds
Time Taken: 0.00603 seconds
Time Before: 0.02315 seconds
Time After: 0.02332 seconds
Time Before: 0.02588 seconds
Time After: 0.02724 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.030146837234497
Time Before: 0.03178 seconds
Time After: 0.03195 seconds
Time Before: 0.03533 seconds
Time After: 0.03678 seconds
SET lastactivity = 1776659819, location = '/forums/private.php?do=newpm&explain=1&u=13929', badlocation = 1
Time Before: 0.05129 seconds
Time After: 0.05424 seconds
Time Taken: 0.00295 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.050356864929199 seconds with 9 queries, spending 0.010563135147095 doing MySQL queries and 0.039793729782104 doing PHP things.
