Time Before: 0.00613 seconds
Time After: 0.00877 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00887 seconds
Time After: 0.00981 seconds
Time Taken: 0.00093 seconds
Time Before: 0.01017 seconds
Time After: 0.01035 seconds
Time Before: 0.01117 seconds
Time After: 0.01344 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01043 seconds
Time After: 0.01769 seconds
Time Taken: 0.00726 seconds
Time Before: 0.02154 seconds
Time After: 0.02192 seconds
Time Before: 0.02469 seconds
Time After: 0.02592 seconds
Time Before: 0.02087 seconds
Time After: 0.02617 seconds
Time Taken: 0.00531 seconds
Time Before: 0.03736 seconds
Time After: 0.03750 seconds
Time Before: 0.04485 seconds
Time After: 0.04608 seconds
End call of global.php: 0.048066139221191
Time Before: 0.05048 seconds
Time After: 0.05067 seconds
Time Before: 0.05306 seconds
Time After: 0.05459 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1776685840, location = '/forums/private.php?do=newpm&explain=1&u=139309', badlocation = 1
Time Before: 0.07246 seconds
Time After: 0.07277 seconds
Page generated in 0.071293115615845 seconds with 9 queries, spending 0.0083966255187988 doing MySQL queries and 0.062896490097046 doing PHP things.
