Time Before: 0.02396 seconds
Time After: 0.03105 seconds
Time Taken: 0.00709 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03113 seconds
Time After: 0.03191 seconds
Time Taken: 0.00078 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03215 seconds
Time After: 0.03231 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03317 seconds
Time After: 0.03539 seconds
Time Taken: 0.00222 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03239 seconds
Time After: 0.03952 seconds
Time Taken: 0.00714 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04935 seconds
Time After: 0.04981 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05258 seconds
Time After: 0.05376 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04856 seconds
Time After: 0.05396 seconds
Time Taken: 0.00540 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.10824 seconds
Time After: 0.10838 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.17739 seconds
Time After: 0.17868 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.22020 seconds
Time After: 0.22039 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.23135 seconds
Time After: 0.23284 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1769815833, location = '/forums/private.php?do=newpm&explain=1&u=139316', badlocation = 1 WHERE sessionhash = '92ff6a36ca798bc15f3564bfe954b6e0'
Time Before: 0.26670 seconds
Time After: 0.26698 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
