Time Before: 0.00185 seconds
Time After: 0.00256 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00267 seconds
Time After: 0.00342 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00377 seconds
Time After: 0.00399 seconds
Time Before: 0.00466 seconds
Time After: 0.00781 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00406 seconds
Time After: 0.01124 seconds
Time Taken: 0.00718 seconds
Time Before: 0.01315 seconds
Time After: 0.01361 seconds
Time Before: 0.01601 seconds
Time After: 0.01735 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01260 seconds
Time After: 0.01753 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02230 seconds
Time After: 0.02249 seconds
Time Before: 0.02441 seconds
Time After: 0.02569 seconds
Time Before: 0.02851 seconds
Time After: 0.02869 seconds
Time Before: 0.03069 seconds
Time After: 0.03217 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139380' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04701 seconds
Time After: 0.04741 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
