Time Before: 0.00880 seconds
Time After: 0.01136 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01146 seconds
Time After: 0.01187 seconds
Time Before: 0.01216 seconds
Time After: 0.01233 seconds
Time Before: 0.01325 seconds
Time After: 0.01573 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01238 seconds
Time After: 0.02029 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02355 seconds
Time After: 0.02376 seconds
Time Before: 0.02641 seconds
Time After: 0.02759 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02286 seconds
Time After: 0.02777 seconds
Time Taken: 0.00491 seconds
Time Before: 0.04669 seconds
Time After: 0.04685 seconds
Time Before: 0.17982 seconds
Time After: 0.18107 seconds
End call of global.php: 0.18339204788208
Time Before: 0.18952 seconds
Time After: 0.18969 seconds
Time Before: 0.19290 seconds
Time After: 0.19443 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1776493410, location = '/forums/private.php?do=newpm&explain=1&u=139387', badlocation = 1
Time Before: 0.21365 seconds
Time After: 0.21391 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.21244812011719 seconds with 9 queries, spending 0.0078234672546387 doing MySQL queries and 0.20462465286255 doing PHP things.
