Time Before: 0.01712 seconds
Time After: 0.02587 seconds
Time Taken: 0.00875 seconds
Time Before: 0.02597 seconds
Time After: 0.02635 seconds
Time Before: 0.02659 seconds
Time After: 0.02673 seconds
Time Before: 0.02743 seconds
Time After: 0.02967 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02678 seconds
Time After: 0.03401 seconds
Time Taken: 0.00723 seconds
Time Before: 0.04505 seconds
Time After: 0.04527 seconds
Time Before: 0.04776 seconds
Time After: 0.04898 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04422 seconds
Time After: 0.04919 seconds
Time Taken: 0.00497 seconds
Memory After: 2,261.719 KB
Time Before: 0.07177 seconds
Time After: 0.07194 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09384 seconds
Time After: 0.09506 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.10657 seconds
Time After: 0.10674 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10956 seconds
Time After: 0.11101 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=13941' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12930 seconds
Time After: 0.12955 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
