Time Before: 0.00170 seconds
Time After: 0.00250 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00257 seconds
Time After: 0.00304 seconds
Time Before: 0.00326 seconds
Time After: 0.00344 seconds
Time Before: 0.00399 seconds
Time After: 0.00626 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00349 seconds
Time After: 0.00961 seconds
Time Taken: 0.00612 seconds
Time Before: 0.01150 seconds
Time After: 0.01181 seconds
Time Before: 0.01367 seconds
Time After: 0.01561 seconds
Time Taken: 0.00195 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01082 seconds
Time After: 0.01586 seconds
Time Taken: 0.00503 seconds
Memory After: 2,261.820 KB
Time Before: 0.02271 seconds
Time After: 0.02286 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02515 seconds
Time After: 0.02676 seconds
Time Taken: 0.00161 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.028542041778564
Time Before: 0.03004 seconds
Time After: 0.03023 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03349 seconds
Time After: 0.03575 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788973485, location = '/forums/private.php?do=newpm&explain=1&u=139419'
Time Before: 0.04973 seconds
Time After: 0.04994 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.048763990402222 seconds with 9 queries, spending 0.0095999240875244 doing MySQL queries and 0.039164066314697 doing PHP things.
