Time Before: 0.00161 seconds
Time After: 0.00225 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00239 seconds
Time After: 0.00279 seconds
Time Before: 0.00301 seconds
Time After: 0.00313 seconds
Time Before: 0.00383 seconds
Time After: 0.00644 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00318 seconds
Time After: 0.00982 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01159 seconds
Time After: 0.01204 seconds
Time Before: 0.01489 seconds
Time After: 0.01617 seconds
Time Before: 0.01092 seconds
Time After: 0.01635 seconds
Time Taken: 0.00543 seconds
Time Before: 0.02123 seconds
Time After: 0.02139 seconds
Time Before: 0.02336 seconds
Time After: 0.02461 seconds
End call of global.php: 0.026196002960205
Time Before: 0.02761 seconds
Time After: 0.02778 seconds
Time Before: 0.02998 seconds
Time After: 0.03147 seconds
SET lastactivity = 1777162866, location = '/forums/private.php?do=newpm&explain=1&u=139487', badlocation = 1
WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.04380 seconds
Time After: 0.04438 seconds
Time Taken: 0.00059 seconds
Page generated in 0.042886018753052 seconds with 9 queries, spending 0.0084884166717529 doing MySQL queries and 0.034397602081299 doing PHP things.
