Time Before: 0.02111 seconds
Time After: 0.02751 seconds
Time Taken: 0.00640 seconds
Time Before: 0.02759 seconds
Time After: 0.02796 seconds
Time Before: 0.02816 seconds
Time After: 0.02830 seconds
Time Before: 0.02899 seconds
Time After: 0.03110 seconds
Time Taken: 0.00211 seconds
Time Before: 0.02837 seconds
Time After: 0.03526 seconds
Time Taken: 0.00689 seconds
Time Before: 0.04638 seconds
Time After: 0.04674 seconds
Time Before: 0.04931 seconds
Time After: 0.05053 seconds
Time Before: 0.04553 seconds
Time After: 0.05079 seconds
Time Taken: 0.00526 seconds
Time Before: 0.07538 seconds
Time After: 0.07553 seconds
Time Before: 0.09516 seconds
Time After: 0.09638 seconds
End call of global.php: 0.098476886749268
Time Before: 0.10361 seconds
Time After: 0.10375 seconds
Time Before: 0.10633 seconds
Time After: 0.10828 seconds
Time Taken: 0.00195 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139491'
Time Before: 0.12970 seconds
Time After: 0.13003 seconds
Page generated in 0.12828397750854 seconds with 9 queries, spending 0.0079951286315918 doing MySQL queries and 0.12028884887695 doing PHP things.
