Time Before: 0.00193 seconds
Time After: 0.00266 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00277 seconds
Time After: 0.00321 seconds
Time Before: 0.00344 seconds
Time After: 0.00356 seconds
Time Before: 0.00428 seconds
Time After: 0.00674 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00361 seconds
Time After: 0.01082 seconds
Time Taken: 0.00721 seconds
Time Before: 0.01327 seconds
Time After: 0.01355 seconds
Time Before: 0.01667 seconds
Time After: 0.01791 seconds
Time Before: 0.01252 seconds
Time After: 0.01810 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02381 seconds
Time After: 0.02397 seconds
Time Before: 0.02580 seconds
Time After: 0.02703 seconds
Time Before: 0.03026 seconds
Time After: 0.03044 seconds
Time Before: 0.03257 seconds
Time After: 0.03400 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=139502', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04691 seconds
Time After: 0.04722 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
